Single phase Inverter Design Formulation
Kunal Kaushikkumar Shah
Joined Apr 20, 2017
6
I am working on 400W, 120Vac, 60Hz-Single Phase Inverter Design (DC-AC), so I need to know where can I find design formulation for it. I searched but didn't find any relevant information.
Design formulation-
1.Gate pulses to the MOSFETs.
2.Input and Output Filter Design.
3.Control loop for Inverter.
Thank you.
Kermit2
Joined Feb 5, 2010
4,159
I have grown used to having to try uploading pdf files twice.
I've tried six times now and I am not able to upload the pdf file yet.
I'm going to reboot and try one more time then I'll give up and go to lunch. :)
Joined Apr 20, 2017
6
Your request is very broad. Perhaps these two designs will be of use.
800 VA Single Phase Inverter Reference Design
Sine Wave inverter for photovoltaic applications
Thank you for your reply.
I have looked at those documents before but it doesn't specify anything on how to design a filter or generate PWM gating signal using some formula.
Also, how do I set the modulation index, Amplitude of reference signal (sinusoidal) and amplitude of carrier l signal (triangular waveform) in order to get-
Vout=120Vac, Pout=400W, Fo=60Hz.
Vinput= 170Vdc.
