- Joined Jan 23, 2018
- 28,077
My guess is that the TS does not want a circuit that consists of a discrete component flipflop, which is a reasonable request. But will the TS accept a circuit using a CMOS or TTL IC??
Not a problem. Electronics has its own language, and learning a new language always is bumpy.I'm sorry you spent time analyzing the video.
That was my first thought, but now . . .Transistors will be damaged by excessive current causing excessive heat, or by excess voltage causing a junction breakdown, leading to excess current. So there is no reason why the relaxation circuit shown would cause damage unless some limitation is exceeded.
Having both a Master Rate as well as controlling the individual frequency is not as simple a task as you might think.There's a potentiometer which adjusts overall flash frequency ("Master Rate" in the schematic), and each LED has its own resistor which is added to the Master Rate to control its individual flash frequency.
HiMaybe one of the LTSpice wizards around here can model this.
ak
I can elaborate on this real quick: As shown in post #1 the device has a variable resistor (1M pot) labeled "Master Rate" which is shared by all 5 LEDs. Between the pot and each capacitor is a permanent resistor labeled "Rate 1" with a different value for each LED. Together the pot and resistor control how fast the capacitor charges which controls the frequency of each LED flash. The circuit is exactly the same for each LED unit, except for the "Rate 1" resistor. (I didn't design the device, I purchased it pre-built. The schematic is exactly what's on the circuit board for the first LED.)Having both a Master Rate as well as controlling the individual frequency is not as simple a task as you might think.
Any standard battery voltage from 3 volts to 12 would be fine, preferably something which can be substituted with a common inexpensive wall charger like those used to charge phones. Thanks for your schematic, I'm hoping to place an order this weekend for parts to experiment with. I'll need to answer your other questions tonight after I get home.What is the intended battery voltage?
If it doesn't actually damage the transistor over hours and days it might be fine, but there seems to be plenty of other solutions available and I'd rather have a long-term reliable solution. (FWIW, I did build that circuit and left it running for three days and it seemed fine, but again there are so many more robust solutions given in this thread.)That circuit was ruled out by the TS in post #1.
In my experience, the Cappels circuit operation is marginal at 10-11 V, and its performance is very dependent on the specific transistor, and varies with temperature, from part-to-part, etc. At 12 V and above I've had no problems.If it doesn't actually damage the transistor over hours and days it might be fine, but there seems to be plenty of other solutions available and I'd rather have a long-term reliable solution.
You could always use a simple 555 circuit along with a USB power cube.
I've decided to start with the schematics provided by Wendy and the AnalogKid, and I may as well try out all of them. I need to order a few parts but I'm sure one of these will get me close to what I want, and maybe I'll try some other ideas later if I get adventurous! Thanks everyone, I'll come back and post my results when I get my order all set!Based on version 1, here are two different fixes for more reliable operation.
