I have a 68 chrysler with single field alternator and external solid state regulator. Could a double field alternator be adapted to work. Tried hooking up and volts jumped up and down up to 18 volts. am I stuck w/double field.
I figured it out. Thank you for your attention.Can you post pictures of the back of these two units. I used to rebuild alternators and starters for a living so I am sure I can help you. Just need to see what you have to work with.
Pretty sure you have an A circuit and B circuit alternator and you should be able to convert one to the other without much problem.
