Sincronized timer with input using 555 in LTSpice.
axri
Joined Nov 1, 2023
7
Hi, I'm trying to get a clock signal of 200Hz which is synchronized with an input.
My approach is that by using a differenciator I can get the falling edge peaks, and trigger a 555 in monostable mode. The problem is that the trigger signal I have is 0V DC so the monostable won't trigger. What I need is that the clock oscillates and when it detects a peak syncronize to it.
This is what I have:
This is the input signal:
And this is the rectified differenciated signal which I want to use to synchronize the timer:
ericgibbs
Joined Jan 29, 2010
21,527
Hi axri,
I can now run that asc file you posted, had to rename the *.txt file to signal2.txt
This is not the same asc file that you show in your first post??
E
BTW: Is this Homework, I see that you are a student?
axri
Joined Nov 1, 2023
7
It is a project I am working for.
I have trouble simulating it as it gets stuck and doesn't run correctly.
axri
Joined Nov 1, 2023
7
Great, thanks.
By adjusting the timer RC values I got to this point:
I have 2.5ms signals at the falling edges, so it is now synchronized, but I need to output the full clock signal.
ericgibbs
Joined Jan 29, 2010
21,527
OK, modify your circuit to give the full signal and post the asc file, I will check it out.
BTW: your circuit layout in LTS is very poor, try my layout.
E
axri
Joined Nov 1, 2023
7
The input signal is just that file.
What I need is to complete the output signal with the full clock like the red signal I draw:
axri
Joined Nov 1, 2023
7
Sorry for the confusion, the circuit works great, just what I wanted.
This will be used in a receptor to recover the clock from a different code.
Thank you very much!
