Simulation of step down converter using LM5146 using p-spice for TI
eetech00
Joined Jun 8, 2013
4,749
I am trying to simulate a buck converter for 48V input to 3.3V 10A output using LM5146 using P-spice for TI, unfortunately not getting the desired output during simulation. Component values are calculated by TI's power calculator excel sheet. attaching simulation files Thanks in advance
Sync you are not using external clock, SYNCIN should be grounded, SYNOUT disconnected.
What are you specifications? Freq? etc.?
There is no pspice schematic in your posted files so could not open.
Papabravo
Joined Feb 24, 2006
22,116
Is P-spice for TI the same thing as TINA?
gok001
Joined Oct 3, 2022
8
Frequency is 300kHz. I am again attaching the file. should be connected to VCC as per datasheet. I am sending the archive project file and this should work
eetech00
Joined Jun 8, 2013
4,749
Change both mosfets to real models instead of generic models.
Use:
CSD18514Q5A
This mosfet is located in the TI category section.
