There are different 78xx voltage regulators. Check the datasheet.
If you are going to buy higher current 7809 then you may as well use the same one for all of the outputs.
If it's still not clear, those diodes on the output will not protect the load against reverse polarity.
How could they?
Reverse protection has to be at the load, not the source.
