ebeowulf17
- Joined Aug 12, 2014
- 3,307
Seems like you're missing some components. You've dropped that boost IC in the circuit in much the same way you could add a linear regulator to reduce voltages, but the boost IC doesn't work by itself. Look at the typical application circuit below.So this would work, then? (In general. I might use a different 3V coin cell, and I probably have some polarities wrong. I usually just test the LEDs as I go to make sure I've got them the right way around.)
I really appreciate all the help!
It appears to require 4 external components. I'll admit I haven't put one of these circuits together before, so I don't claim any expertise, but just based on what I see in the datasheet, it looks like you need more parts.
