Simple question regarding Ideal Op Amps
38,820
Why would it be negative, since PSC says says current entering a a resistor enters a + side, thus making the voltage +.
Which resistor? (You should label all the resistors).
You stated the negative node is zero, so what must the polarity be at the Va node for the current to go in the direction you show through the 60k resistor.
enemias
Joined Sep 21, 2019
10
Ok, so. since the negative node is 0, the current must flow to a lower voltage, meaning V_out will be negative? meaning at the node shared among the the resistors its -1.8V. So according so voltage V_a = -1.8V - Ground (0 V) = -1.8V? Sorry about not understanding this, i cant grasp negative voltage yet.
38,820
Yes, it is negative.
The circuit is a common op amp inverter circuit, meaning the polarity of the output is always opposite the input.
So now that you know Va with its polarity and the current through the 60k resistor, you can calculate the current through the 40k and 30k resistors.
From this you can calculate the output voltage.
It's the yang of positive voltage. :)
Voltage is always between two nodes, so if one node is positive then the other node is negative with respect to that.
In this case you are measuring voltages with respect to ground, which can be considered the positive or negative node, depending upon the other nodes polarity.
enemias
Joined Sep 21, 2019
10
Ok, is it right to say that the current at the 40k resistor is flowing from ground to -1.8V? Since current always flows from Higher voltage to negative voltage? If so, how is that possible since there isnt any source to give current. Also, can i visualize all that grounds like if they were interconnected? im sorry im bombarding you with questions, hehehe (also if you have any videos that might help me visualize negative voltage lmk, i understand negative current)
38,820
Yes, but it's not a "higher" voltage, it's the positive node (which here is ground).
Current always flows from the positive node to the negative node.
But there is a source.
It's the negative node (which is being generated through the 30k resistor by the op amp output).
A source can be positive or negative.
Try to understand that there is no inherent difference between positive and negative other than to indicate the relative polarity between two nodes.
Yes, all ground symbols are connected together.
There is no voltage difference between them.
Ground is just an arbitrary point that all circuit voltages are referenced to.
It has no other significance.
enemias
Joined Sep 21, 2019
10
Thank you so much, you helped a lot!
