Good day MATLAB gurus.
I recently purchased MATLAB, and am trying to get started using a neural network. I have had no prior experience working with MATLAB, but I did complete the MATLAB Onramp course online. I have built my first neural network (converting degrees celcius to degrees farenheit) and it worked well! So that's where I'm at - so please excuse my lack of experience.
I think my question is quite simple. Hopefully it might be just as easy to answer.
How do I increase the number of hidden layers in a neural network using the MATLAB nnstart command and pattern fitting GUI? My second question is; how do I generate the code that the GUI uses to find the solution? Just to confirm: I'm not asking how to generate the output code for the NN training (that's quite simple). I want to see the code that the GUI uses to find the NN solution.
There appears to be no way of increasing the number of layers at this point...
Thereafter I would like to see the code that made this whole process possible.
Is there a solution to the two questions? Can anyone help me?
I would appreciate the assistance. I'm trying to learn, so please be gentle.
- Typing "nnstart" in the command window gets me:
- I click on "fitting app"
- Go through the setup process
- arrive at the following window:
