Simple pulse generator from switch state change
Francesco Boscarino
Joined Jul 4, 2018
6
I'm trying to figure out how to design a simple circuit (RC + BJT) which could output a low pulse (10ms) whenever a switch is opened and closed.
Any idea?
AlbertHall
Joined Jun 4, 2014
12,660
You want this pulse to happen when the switch is closed and then another pulse when the switch is opened?
One problem to be solved is that some switches 'bounce' for longer than 10ms so when the switch closes you might get multiple output pulses triggered.
AlbertHall
Joined Jun 4, 2014
12,660
In this circuit V1, R1, Q3 and R7 are just for the simulation. Your reed switch would connect where Q3 collector and emitter are. The collector of Q4 would connect to the controller reset pin.
It would be a good idea if someone better at LTspice checked this out. I haven't tried using 1MΩ resistors in this type of circuit before. Given that this circuit is to wake up the controller from deep sleep clearly current consumption needs to be minimised.
Alec_t
Joined Sep 17, 2013
15,162
Assuming the reed switch closes when the gate is in the closed position, here's an alternative which draws only 5uA with the gate closed and virtually zero current with the gate open :
Only two of the four gates in the IC are used.
C2 suppresses switch-bounce. R2 limits the C2 discharge current. R3,C1 set the output pulse width.
This circuit should work on a 5V supply or a 3.3V supply; whatever suits your MCU.
