simple math problem on electrical motor
HoopHoop
Joined Aug 22, 2016
24
if a 3 phase induction motor of 5 hp has speed of 1430 at rated load then what is its speed at 50% load?
please expalin.
thanks.
MaxHeadRoom
Joined Jul 18, 2013
30,813
please expalin.
That is never going to be the same for each motor, individual characteristics of the motor, stator/rotor etc, come into play.
The example motor in the question would be a 50hz motor.
Max.
Kermit2
Joined Feb 5, 2010
4,159
Figure out the synchronous speed of the motor. Assume the line is 50 hz.
It is an induction motor. Induction motors produce ZERO torque at synchronous speed.
Yours produces 100% of rated torque at 1430 rpm.
Slip is a ratio of two numbers.
A ratio is the division of one number by another such that the mathematical answer is equal to or between 1 and zero.
If you can't get there from here then you are wasting time trying to learn this particular subject.
