Simple Line following robot without microcontroller
kingcobe
Joined Sep 28, 2023
Hello allaboutcircuits forum, anyone knows this circuit? i try to make design but i dont know if its correct, please check my design below
using tinkercad i make this design, do you think its correct? and please tell me where should i put pin 2 and 15 of l293d to lm358/here on the design. The green led is the IR receiver while the gray/white is the IR transmitter, thank you allaboutcircuits forum
MaxHeadRoom
Joined Jul 18, 2013
30,810
How do you intend to follow the line, most line following methods I have seen the that do not use a micro, use only one retro reflective source that is oscillated across the line ?
Or is this a dual line method?
kingcobe
Joined Sep 28, 2023
yes, this is dual line method. 2 IR sensor is connected to lm358
