I have a simple question that I cannot, for the life of me, solve.
The premise is simple: I need to turn ON/LATCHING relay using a momentary programmed switch that closes and supplies 12vdc for 25ms, and have it stay LATCHED until the same programmable switch closes again for 25ms, providing another 12vdc pulse. This would turn OFF/UNLATCH that same relay. The latch action shorts a gate circuit for 10 hours via the programmable switch, and then unlatches via that same switch. The shorting action keeps the gate open. The home development wanted a programmable system to open the gates automatically at 630am and close again at 830pm.
This is a remote solar powered system opening and closing gates so I went with a latching relay to minimize power draw. So after latch and unlatch operations there should be zero power draw. The only power used is twice a day for less than a second to latch/unlatch.
Problem is... I cannot find a latching relay that simply LATCHES on a simple closure that supplies temporary 12vdc for 25ms, and later UNLATCHES using the same 25ms closure. I've been through three boards and a latching relay from Amazon but ALL of them need a set/reset function that requires power during the duration of set or reset. A simple automotive latching relay that I thought would work requires REVERSE polarity through the coil to latch/unlatch.
All circuits are 12VDC. Again, this is a solar powered system driving the gate control board and an automated scheduler (Altronix PT2724A) that I installed in the box with the controller as part of my modifications. The gate control and the scheduler use about 54ma total in normal use and control (2) 3000XLS gate arms. There are (2)12v7AH batteries and (2) 10 watt solar panels that supply power 24/7 to the system. There are no local power options.
I've attached a PDF of my design and layout. The relay is to the right of the scheduler and shorts "SHADOW" to "COM" to hold the gate open, preventing the autoclose. This was recommended per GTO tech support.
If anyone has suggestions or could point me in a general direction I would greatly appreciate the help. This is the last thing holding me up from finishing. Thanks for reading.
