Simple frequency converter
Pyrex
Joined Feb 16, 2022
556
sometimes i need a power source to run a small single phase asynchonous motor at half speed . It's well known that such a power source should generate 25 Hz and 110V for a motor rated to 230V and 50 Hz. A lot of frequency converters available at the moment, but i do not need a dozens of various modes, functions and numerous menus... In addition, FC is a bulky and expensive device to be used with motor rated at 30 or 50W.
So, a circuit was found in the net:
http://www.frequencyinverter.org/frequency-converter-50hz-to-60hz-design-821996.html
A dozen of users posted their questions at the end of the article. Unfortunatelly, two of them reported the FC burned down... What's may be wrong with it? Transients at startup?
And one more question- what i need to do to generate more sinusoidal output? Asynchronous motors don't like "modified sine wave". Use another type of counter intead of 4029' ?
Thanks in advance
Alec_t
Joined Sep 17, 2013
15,158
There are various reasons, depending on which component 'burned down'. To name but a few: excessive load, highly inductive load, inadequate supply decoupling, under-specified capacitor ratings, inadequately-rated FETs, failed drive logic, .......
Use a far more complex circuit, involving PWM, to generate a so-called 'pure sine-wave' inverter.
Pyrex
Joined Feb 16, 2022
556
There's no mistakes in the circuit diagram, you mean?
Alec_t
Joined Sep 17, 2013
15,158
That's not what I meant. But now you mention it, I see pins 12 and 13 of the CD4001 are floating. That's a mistake (although the write-up does say how it should be fixed).
Pyrex
Joined Feb 16, 2022
556
Yes, i agree.
Anyway, those unused 4001" inputs can't affect the overall perfomance
Papabravo
Joined Feb 24, 2006
22,114
Yes, i agree.
Oh, but they can. An unused input on a 4000 series CMOS device can oscillate causing other devices in the package misbehave as well. This is the difference between engineering and hacking. You get what you pay for.
Pyrex
Joined Feb 16, 2022
556
From my practic- input of CMOS was left floating... The result was relatively huge current drawn by CMOS package- miliamps instead of microamps:)
No more essential mistakes , except of floating CMOS inputs ?
