I been wanting to make a simple fan controller for my PC using rotary pot's with knobs on the front panel and some LED's. I have an old AC to DC adapter that outputs 12V DC at 1A, to use as a test bench for my project.
This is what I have came up with using simple 1k pot's and two 80mm fans that I had from old non working power supplies.
I have the pots set around 80 ohms, and the I have a red LED running parallel acros the source with a 470 ohm resistor.
Instead I would like to put an LED for each fan that I want to control with a rotary pot with a built in switch. So when I do turn the switch off, the LED turns off and the rest of the fans remain on.
This is what I came up with so far...I know it needs more work.
