Simple DiY 40a PSU / Ac-Dc converter
bigjoncoop
Joined Feb 1, 2019
204
Hey guys,
I need to get anywhere between 12v to 24v DC @ ~40amps. All the power supplies I can find are $100+ ....
I need this to power a large 1500w CC/CV boost converter to charge a large lithium ion battery pack which will be going thru its BMS.
I've been keeping my eyes open for even a used server power supply etc... But again haven't found anything under $100 but normally a lot more.
I don't know how clean the DC needs to be going into the boost converter but...
I wasn't sure if it would be as simple as going through a transformer or bridge rectifier then into a large coil and some capacitors and what not. Or maybe modding a smaller psu to handle the current
Just trying to save money on this project since I'm already got too much into it.
Irving
Joined Jan 30, 2016
5,195
There are plenty of Dell/HP server PSU @ 500 - 700W each on ebay.com for around $30 each. You're honestly not going to do it cheaper if you want 1200 - 1500W @ 24v. There's a listing there now for HP 750W @$20ea
SamR
Joined Mar 19, 2019
5,542
SMPSs get a bad rap but every critical computer runs on one. Maybe not as suitable for a research-grade electronics lab when looking for a mV or uV supply but I use them to supply my HF XCVRs and Amps. Suitable and value-priced depending on use. Plus there is a LOT of them available surplus for a very good price.
Irving
Joined Jan 30, 2016
5,195
I use a modified SMPS for a variable 0-50v, 25A bench 'lab' supply. It is a little noisy on the output but the 80 - 120kHz switching is easy to clean up with an LC filter (much easier than if it were 100Hz hum from a linear regulator).
SamR
Joined Mar 19, 2019
5,542
Yup, I just ran into a situation where I needed a 3rd PSU and thinking I might just have to do a conversion job on one of the junk computer SMPSs I have to fill the bill. But I also have a couple of dish tubs full of wall warts to chose from. LOL
Irving
Joined Jan 30, 2016
5,195
You can never have too many PSU! I picked up a useful 4-channel linear bench supply on eBay for £90 ($120) (Instek PS4303) - used and ch2 voltmeter is a little flakey (probably a dry joint, it is 20y old after all!).
