Dear community members,
In my hands there is a 'PLC-alike' device originated from some local very little-known manufacturer.
Purpose of this device is transmission of binary and telemetry data from remote sites(HV substations etc) through GPRS modem with use of IEC 60870-104 protocol to some SCADA-alike software.
There are more than 400 devices of this type being used for a while(4 years). Most of them appx. 2/3 do operate properly, the rest after some years(1-2) of proper operating lost GPRS connection with the server(do not respond to ping (<Sim IP>) command). Please have a look at the device pics below:
The "IMX287" consists of two PCB's. The first pcb above is modem itself with power linear rectifier MIC29302 which feeds SIM800C(and the rest). This PCB has a slot for a SIM-card. There are circuits for the binary inputs on this PCB, they work properly. The second PCB is a computer. The soft runs from SD card.
The problem is after being powered on, it fails to establish connection. Software keeps modem attempting to establish connection, when it fails it waits for sometime, and then restarts modem, etc. Please have a look into the 'schematic diagrams' archive. The file 'Схема платы' refers to modem pcb alongside with MIC29302 power rectifier.
I have been adviced how to diagnose faults of this device by the individuals who have designed modem PCB, assembled and programmed it without much success. And therefore they suggested me to have a check the voltage value before U1(MIC29302) U1(5V) and after U1 'Vbat' that should be within 3.4-4.4 V range. Also within 1 min after powered on there must be a short negative slope on the PWRKEY path. Please have a look into archive 'Oscilloscope samples' regarding U1, Vbat and PWRKEY signals.
Dear gentlemen, my objective is to diagnose the possible reasons of the faulty operation. And performing possible repair if the reason is discovered.
I believe with the precious advices of yours, at least possible reasons of faults could be found.
Yours faithfully.
N.Qv.
Yours faithfully.
N.Qv.
