The issue isn't about the cable length. One can have reflections in short cables. The issue is about impedance mismatch at the ends of the cable. Reflections don't commence until the travelling wave propagates to the point of discontinuity - such as the mismatched load impedance.Hi
Can someone explain to me why we have signal reflection on long cable? What is the equivalent circuit of a long cable?
Thanks guys!
Transmission lines are modeled as a distributed series inductance (microhenries per foot), and distributed shunt capacitance (nanofarads per foot). This ideal transmission line leads to a partial differential equation, which given certain boundary conditions, can be solved for the explicit waveforms.Hi
Thanks guys!
This video might help you understand signal reflection and how the distributed properties operate.Hi
Thanks guys!
The principle of conservation of energy. Unless the energy propagating along the cable is converted or absorbed, it must continue to propagate. As the propagation medium doesn't extend past the end, the energy must return towards the source, along the cable (less whatever propagated into free space)Hi
Thanks guys!
Can I say that maximum power (W) is transferred the source (cable) impedance matches the load impedance?Reflections in a cable are related to the maximum energy transfer theorem which states that the maximum energy is transferred when the source (cable) impedance matches the load impedance. If the two impedances are not matched then the energy not transferred to the load has nowhere else to go and is reflected back down the cable.
I agree that the old AT&T video showing a mechanical representation of wave propagation and reflection is simply fantastic.This video might help you understand signal reflection and how the distributed properties operate.
https://www.youtube.com/watch?v=DovunOxlY1k
A video worth a thousand word, thanks a lot.I agree that the old AT&T video showing a mechanical representation of wave propagation and reflection is simply fantastic.
You might also find one of my videos on the same topic useful to understand reflections.
http://www.youtube.com/watch?v=Il_eju4D_TM
Cool. We can see the effects of a discontinuity in impedance in fiber optic cables also.You might also find one of my videos on the same topic useful to understand reflections.
Thanks for the number, can I understand the number like this: if the cable is say 1m, the refection won't be significance.Yes, you can try this but pay attention to the numbers.
Speed of light is 3 x 10^8 m/s.
The inverse of that is about 3ns/m.
If we use a velocity factor of about 66%, we end up with 5ns/m.
Thus 10m of cable would give you a round-trip reflection of about 100ns.
So you need:
1) a signal generator with fast rise-time that is less than 10ns
2) an oscilloscope with 100MHz bandwidth or higher
3) about 10m of cable
Hi MrChipThat's not correct thinking.
The round-trip with a 1-metre cable will be 10ns. This produces "ringing" at the edges of the signal. The reason you may not see it is a combination of the rise-time of the signal may not be fast enough and the bandwidth of your oscilloscope is not high enough.
Actually it's the opposite. The characteristic impedance of transmission cable is determined mainly by it's distributed capacitance and inductance. It's interesting that the value of this is given in ohms, the same as a resistance, and is theoretically independent of frequency and cable length. The distributed resistance of a real cable wire is normally much less than its characteristic impedance.So if I understand it correctly, inductive and capacitive of a cable has no/little effect of the refection of a signal transmitting on the cable?
Yes it is, the distributed LC elements model the impedance of the dielectric between the conductors where the energy flows. Real resistance (in conductors and possible dielectric loss) is seen as transmission losses and the dielectric impedance is seen as the confined space that the EM EB fields travel in-phase when impedance matched so it's seen as resistive but not dissipative (most of the energy is constrained between the conductors). When we have reflections and standing waves from an impedance mismatch the phase of the EM fields changes making part of the cable impedance reactive along it's length.It's interesting that the value of this is given in ohms, the same as a resistance, and is theoretically independent of frequency and cable length. The distributed resistance of a real cable wire is normally much less than its characteristic impedance.
No you did not say that, it's just me try to understand what you said, and repeat it in a different way, if you confirm it, I know I get it right, otherwise I know there is something I still don't understand.Did I say that? I don't think so.
The inductive and capacitive properties will determine the characteristic impedance of the cable which in turn will affect transmission line reflections.
