Playing with the circuit below, I noticed that this inverting output is off by about 90 degrees. It should be 180 degrees. (I may have the angle confused here) The circuit is built on solderless breadboard.
As I'm thinking about it, say I want to split the signals from the source, and then output in sync. Like, two channels to an amplifier. If I filter one channel, and not the other, would not the signal be out of sync? Maybe just buffer the other channel so they sync up? Are they ever truly in sync?
