Hello everybody! I thought I could handle this project without too much help, but obviously that's not the case, thus my 1st post here.
I am setting up a notebook PC for data acquisition: specifically voltage (0 to 10VDC), Current (3 - 100 A) and Temp (20 - 100C). I have the data acquisition module, and it works well. My task is to create preferably isolated signal gathering and conditioning units for each of the three channels.
I decided to tackle current first. I have a variety of shunts but decided first to try one of the hall-effect modules that can measure DC. I bought two... A Tamura L08P100D15, and a Honeywell CSLA2CD. I started with the Tamura first. Data Sheet This has to be the worst data sheet I've ever seen. Anyway, the unit uses +/-15VDC, and despite my best efforts at hacking around a bit with a unipolar supply, I could not get it to work.
I then tried the Honeywell (Datasheet, even less info!) And it worked fine, but the basic Vout is Vcc/2, meaning 4V with zero amps, and increasing linearly from there.
What I'd really like is an output that starts at zero, not Vcc/2. The latter means I'd need a very accurate, stable voltage (8V) to power it, no drifting allowed. Any thoughts? How do I "shift" the output of the Honeywell, or can I make the Tamura work with a unipolar supply, as its output does start at zero. Thank you all!
