Signal conditioning circuit of the LM335 temperature sensor
krishnapatelzz
Joined Dec 1, 2019
I wanted to ask what topics would I be required to learn in order for me to design this circuit :
Adapt signal conditioning circuit of LM335 temperature sensor to the MCP9701 so it will operate between the range of −15℃ to +110℃. And Use an OP177 Op-Amp.
ericgibbs
Joined Jan 29, 2010
21,641
hi krishna,
Welcome to AAC.
Have you studied the datasheet for the LM335.?
What voltage range do you require from the output of the OPA.?
E
