Siglent oscilloscope decreasing signal ?
Zeeus
Joined Apr 17, 2019
616
ignore title
Noticed that my scope, going from 200uS/div to 100 micro-secs/div then the signal reduces by half
why? how to cure?
dunno if can post this : Anyone interested in changing scopes :) or spectrum analyzer for scope (SDS 1104X-E 100MHZ 4 channels)
Feeling generous to trade higher MHZ for this? RF beginner: spectrum analyzer need but broke :(
Thanks
Mod edit: updated title. Satisfactory? JohnInTX
Depending on your budget you can get a hack rf one which can both receive and transmit 1MHz to 6GHz for only $320. If you don't need to transmit and you have a limited bandwidth then you can get an rtl-sdr for like $20 on amazon.
tautech
Joined Oct 8, 2019
507
Hi, just joined to help with this.
First you should not be seeing such confusion on this scope and can I ask what firmware version you have installed as the latest V6.1.33 is a very worthwhile upgrade if you don't have it installed.
You can get it here:
https://int.siglent.com/download/firmwares/?ProId=12
Some screenshots showing what you see can help us explain what's going on.
Moderators note : removed self-promotion line from the post; member is with a Siglent distributor.
tautech
Joined Oct 8, 2019
507
Had time to grab some screenshots of a 5 KHz sine wave at 200us/div and 100us/div demonstrating what you should see.
Zero issues with amplitude changes:
