Si4735-A10 Radio Receiver IC
KURT44
Joined Aug 19, 2026
5
I'm new to this forum and I don't know if I'm in the right section, please correct me.
I'm retired and as a hobby I will build a multi-band radio using Arduino Uno, Si4735-A10 radio receiver IC plus other required components like audio, LCD screen etc. I understand the Si4735-A10 comes in several variation and I'm not sure which one to select. Can you suggest which one will be suitable for a multi-band radio?
Thank you
Can you tell us what bands you plan on listing to? I'm not sure on that specific chip, but there are some that cover 5MHz all the way to 2.0GHz which is a pretty big range. If you plan on listening to anything in that range, it may not matter which unit you get? So what bands, AM, FM, SSB, digital, etc. That may help others to help you. ;-)
KURT44
Joined Aug 19, 2026
5
Thanks for your time PadMasterson,
I do this project to learn electronics as a hobby and perhaps my selection of a multi-band radio is way out of my knowledge in this field but it will "push" me to learn more. After searching I have purchased "Si4730-D60-GMR, PL102BA-S V2.1" which the specs say it is AM/FM only but some threads say it is multi-band. As I understand this IC is mounted already in a board including everything it needs to function. At this stage it's not important to me if I have only AM/FM or multi-band since the main task is to learn electronics.
If I had purchased just the Si4730 chip I would have to mount it on a board including the required resistors, capacitors, crystal etc. and without any help I would have never being able to complete this work.
Right now I have all the parts I need to build the radio except the ...D60-GMR... which should arrive September-4.
Many thanks again
35,040
I don't know your level of electronics experience. However, I would always recommend starting off with a simple crystal radio circuit. It is quite amazing and satisfying to be able to pick up a MW-AM signal with just a long wire antenna, a proper ground, a germanium diode, and a high-impedance headset.
I used the part many years ago. That little square IC is a bitch to solder by hand. Get an evaluation board something like this. Now you can do the software. I think in the application notes there is software to make the LCD work and the buttons.
KURT44
Joined Aug 19, 2026
5
Thank you MrChips,
My first experience in electronics was in February 2025 when I bought an Elegoo kit and completed a 3 wheels robot. Besides the robot, the kit also had 22 lessons parts included building various gadgets which I found very interesting.
Regarding the crystal radio I remember I built one back in the 50's and now at first I was thinking to build one again but more "fancy" however I decided instead to get more involved and go for a multi-band radio.
Much appreciated
What I bought instead
Good job. I think you can make it work. There are many application notes and example code from Silicon Labs.
I found the part very interesting. I did broadcast engineering for a while. I think in frequency like 100mhz. The engineers I worked with at Si Labs think in time. (10nS) It took too long to 1/X my thoughts. You don't need to know this but there are very interesting things happening in that IC. It is nothing like an analog radio.
KURT44
Joined Aug 19, 2026
5
Very happy to hear this ronsimpson,
I have copy and study some of the application notes / code available and find them very helpfull.
