Does it? Say if I have 30A going through, that would be 30 * 30 * 0.1 = 90WThat one has room for head, shoulders, and a fat mother in law!
I hope you got it in the surplus bin and paid about 98 cents.![]()
Is this the right way to estimate the power?
I'll keep it in mind, thanks!Just remember 50W and 100W resistors generally require a LARGE heatsink to safely reach their rated max disspation.
Just because the resistor is big, metal and has little fins doesn't mean it can dissipate 100W all by itself...![]()
Thanks for the reply! That's right, no heat sink at the moment, I'll try adding something.You have a lot of little things that may be adding up.
You stated you have no heat sink? The little S08 IC has terrible thermals without a PCB board heatsink.
At 22 amps the diode has the same problem.
The 324 can only drive within about 1.5 volts of the positive rail and then only about 20ma. So if possible raise the voltage to it so the fet will turn on harder. You might as well make the gate resistors 150 ohms or so.
If you read the first post, you'll see that it IS my thread...Perhaps you should start your own thread...
Between 13.5V-14.4V.What voltage is Vdd?
What value should it be? Around 10K?Pull down resistor on the MOSFET gates.
I measured the motor drawing as much as 22A. Accordingly to Arduino docs, PWM frequency is about 490 Hz.How much current does the motor need? Either way you should not be getting that much power dissipated in the mosfet, unless the mosfet is staying largely in the linear region and dissipation lots of power. What is your gate frequency? Could you post some shots of the gate voltage, D-S voltage and current look like?
Would you recommend getting that one?This one would probably do it without a heat sink. It will still be real toasty.
http://www.mouser.com/ds/2/302/PSMN1R1-30PL-352613.pdf
