Shorting an input to a TTL logic gate
Papabravo
Joined Feb 24, 2006
22,111
Depending on what you mean by large, doing what you suggest has a good chance of destroying the device. Is that your intention?
OBW0549
Joined Mar 2, 2015
3,565
How can one avoid shorting an input to a TTL Logic Gate?
My answer:
Slightly adding large current to the gate.
As stated, your question and your "answer" make absolutely no sense whatsoever. Try again with a clear, detailed description of exactly what it is you are trying to determine, then we may be able to help you.
WBahn
Joined Mar 31, 2012
33,135
My guess (and that's all it can be with the information given) is that it is talking about overriding an input that has been hard tied either HI or LO.
