shorted LED battery indicator
Poor old sod
Joined Jul 25, 2017
156
S889ER shoprider mobility scooter. it won't now goat all. what have i done, pls. main 50A fuse ok. batteries charging. batt indicator is driven off power to on switch. not sure what volts there, big spark. drive was not selected. no power there now, wigwag appears undamaged? don't have schematic. prob analog controller. it's old enuff.
Poor old sod
Joined Jul 25, 2017
156
wigwag is name for fwd/reverse selector, a center stable 5k pot, 35 deg sweep each way to fsd. The stabilizing spring is far too strong for my weak fingers.
This is the circuit diagram of a 3 LED bar graph type battery monitor circuit Can u plz recommend a similar voltage level indicator circuit for a 24v battery bank a high and low power circuit short together – the low power cable gets so hot.
iMessage Download
Poor old sod
Joined Jul 25, 2017
156
sydney,
yes, that's what happens. remove short and hope wiring ok. cct may be ok iff the supply wires were shorted. i don't know what is between my shorted wires and the battery, but as its a non runner, something has been damaged. i'm here to find out what so i know how to fix it.
