shold I buy these old scopes for a few dollars?
ScottWang
Joined Aug 23, 2012
7,509
If you want to buy a scope for second hand, you should ask them to guarantee that the scope is good, or you can fix it by yourself.
I had bought a IWATSU SS-7821 200MHz, and I didn't use it very often, but after one year later, the scope was damaged, when I tried to fix it with my friend, we checked out all of the parts which could be damaged, the result was that the CRT was damaged and there is no way to fix it.
And then I bought another old one IWATSU SS-7810 100MHz, it cost about US$100.
We can buy a old 20Mhz scope around US$10~40 in Taiwan, it depends on the conditions of scope, that is guarantee the scope is good.
You can also to download a sound card scope to test it, but the input signal have to be less then 1Vpp, of course you can using the resistors as a voltage divider to reduce the input voltages, and it has a signal generator, you can use it to test the audio amplifiers.
Sound card scope.
dentaku
Joined Jul 29, 2013
45
