Shift register 74HC165 current limiting?
poddy
Joined Mar 31, 2005
Hi all,
I'm totally new to this hobby, so please forgive me if my question is too stupid...
If I wan't to use a shift register similarly as below how can i make sure that the current through the chip isn't too large? Is there some internal resistance for the input pins? If I connect a +5V battery to the +5V and flip the switch then, without a resistance, the current would be very large, no?
I hope my question makes sense and you can help me out.
Thanks!
- HP
ericgibbs
Joined Jan 29, 2010
21,654
hi poddy,
The 74HC165 will only draw a few micro amps from the 5V supply,
The 470R in series with the LED is also used to limit the current drawn thru the 74HC
E
dl324
Joined Mar 30, 2015
18,524
It would be out of the norm for logic IC's to have current limiting resistors.
The information you want is typically in the datasheet.
For 74HC165, the recommended maximum output current depends on supply voltage.
Large is a subjective term. Large enough to destroy the LED? Probably not. Large enough to damage the shift register? Possibly.
74HC outputs will withstand brief shorts. This is from a 74HC guide:
