I am recording data from sensors outputting a low voltage signal (mV) but have been getting noise that I'd like to minimize. I've noticed the noise only appears when an infrared heating lamp near the sensors is set to anything less than max output. The lamp runs on 3 phase 480Vac and output level is set by phase angle controlled solid state relays. Due to space constraints, sensor wires cross over the lamp's power supply cable.
Is there a way for me shield the signal wires to reduce the noise level on the sensors? If so, what material would be best for this. Thanks!
