I wanted to design a simple circuit to monitor a charging voltage. Ideally, I'd like to have an input voltage between 0 and 12V, whereas at about 7V (tunable) an LED should switch on, below it turns off again. First I thought I can solve this simply with a Zener diode, however, when reaching the Zener voltage I still have a not-sharp slope in the current, so my LED turns on "slowly" (it should happen within 0.1V to full brightness). Also, when increasing the voltage to 12V, it simply blows the LED, and using a resistor for once delays the turn-on of the Zener and then reduces the brightness.
I played around with op amps and Schmitt triggers, which kinda led to the expected result, but both usually require an external amp source, which I don't want - I want to use the supplied voltage on the line, which is enough to power an LED. Furthermore, the trigger does not reset when simply turning of the input. Does anyone have a solution for me?
/Andre
/Andre
