i want this code to hold the servos position please help this is the code
C-like:
#include <Servo.h>
#define VRX_PIN1 A0
#define VRY_PIN1 A1
#define SERVO_X1_PIN 2
#define SERVO_Y1_PIN 3
#define VRX_PIN2 A2
#define VRY_PIN2 A3
#define SERVO_X2_PIN 4
#define SERVO_Y2_PIN 5
Servo xServo1;
Servo yServo1;
Servo xServo2;
Servo yServo2;
int xAngle1 = 90;
int yAngle1 = 90;
int xAngle2 = 90;
int yAngle2 = 90;
int deadZone = 10; // Dode zone waar kleine bewegingen genegeerd worden
void setup() {
Serial.begin(9600);
xServo1.attach(SERVO_X1_PIN);
yServo1.attach(SERVO_Y1_PIN);
xServo2.attach(SERVO_X2_PIN);
yServo2.attach(SERVO_Y2_PIN);
void loop() {
int xValue1 = analogRead(VRX_PIN1);
int yValue1 = analogRead(VRY_PIN1);
int xValue2 = analogRead(VRX_PIN2);
int yValue2 = analogRead(VRY_PIN2);
// Implementeer de dode zone
if (abs(xValue1 - 512) > deadZone) {
xAngle1 = map(xValue1, 0, 1023, 0, 180);
if (abs(yValue1 - 512) > deadZone) {
yAngle1 = map(yValue1, 0, 1023, 0, 180);
if (abs(xValue2 - 512) > deadZone) {
xAngle2 = map(xValue2, 0, 1023, 0, 180);
if (abs(yValue2 - 512) > deadZone) {
yAngle2 = map(yValue2, 0, 1023, 0, 180);
xServo1.write(xAngle1);
yServo1.write(yAngle1);
xServo2.write(xAngle2);
yServo2.write(yAngle2);
// Print de gegevens naar de Serial Monitor
Serial.print("Joystick 1: ");
Serial.print(xValue1);
Serial.print(", ");
Serial.print(yValue1);
Serial.print(" => Servo Motor 1: ");
Serial.print(xAngle1);
Serial.print("°, ");
Serial.print(yAngle1);
Serial.print("° - Joystick 2: ");
Serial.print(xValue2);
Serial.print(", ");
Serial.print(yValue2);
Serial.print(" => Servo Motor 2: ");
Serial.print(xAngle2);
Serial.print(yAngle2);
Serial.println("°");
