hx711 loadcell, servo motor, arduino uno r3
althanimac9
Joined Mar 29, 2022
Hello everyone, im a beginner at coding. I want to create a project on hx711 loadcell and servo motor. How it supposed to work: I have 1kg load cell. If i put an object heavier than 500 grams the servo motor motor will turn from 0 degree to 90 degree in 15ms. unfortunately I can't integrate the codes of hx711_ADC and Servo. Im only basing my knowledge on existing libraries. Can someone help me code and explain how it works? Thank you
althanimac9
Joined Mar 29, 2022
hi a9,
Welcome to AAC.
Post the Arduino Sketch you are testing.
Which model of Servo are you using.?
E
Hello Eric, im using TowerPro MG996R. While the arduino sketch im using is just <EXAMPLE> from arduino software. Doing so both hardware, servo and load cell, works accurately but I can't figure out how to code them to make it work simultaneously while carrying out its intended function.
ericgibbs
Joined Jan 29, 2010
21,622
hi a9.
I have a 5kG L/C + HX711 and a SG90 Servo + Arduino on my work bench, so if you post the Code I can run it.
Let me have a copy of your code.:)
E
