Has anyone written code to use pots to control the speed and maximum throw of a servo
Hi Albert, thanks for the reply... yes arduino, my real question is how to have limits entered via pots that the end user would set to A control the max throw, B how long it takes to get there. C how long it stays at the max throw and D how long it takes to get back to the home position.What uc are you using?
There is lots of info for controlling servos with an arduino: https://www.google.com/search?client=firefox-b-d&q=arduino+servo+motor+code
Thanks, I design them then have them 3d printed then make them run when I can. I will try the wide angle you suggest. Some of the earlier clips were done using a cameraGood models!
Just a pointer...
Hold your phone horizontal when videoing. I see so many vertical videos and it just wastes screen space as all TVs and monitors are horizontal.
Research the Arduino map() command. It can take the ADC measurements and map them to any range of integers that you want.Hi Albert, thanks for the reply... yes arduino, my real question is how to have limits entered via pots that the end user would set to A control the max throw, B how long it takes to get there. C how long it stays at the max throw and D how long it takes to get back to the home position.
I did the same a decade before you.will do thanks. I am a guy that learned on fortran and punch cards in the early 70's ha ha
by Jeff Child
