serial regulator
pwnstars
Joined Feb 29, 2016
44
Current at Q2 emitter is current in R4 and RL added.
2.82 mA + 103.3 mA = 106.12 mA
Current in Q2 base is Q2 emitter devided by the min. gain
106.12 mA / 20 = 5.3 mA
Current in Q1 base is, Q1 emitter (/Q2base) devided by the gain.
5.3 mA / 50 = 106 µA
Current in Q3 collecter is current from R1 subtract Q1 base
1.55 mA - 106 µA = 1.44 mA
Current in Q3 base is collecter devided by the gain
1.44 mA / 110 = 13 µA
Which I should consider negligible?
What if the current here was a value of relevance, wouldn't that change the current in the entire curcuit?
Zener diode current is Q3 emitter, which is the same as Q3 collecter, added with the current coming from R2
1.44 mA + 18.4 mA = 19.84 mA
Guess thats it.
pwnstars
Joined Feb 29, 2016
44
Voltage drop in Q2 is Uin subtract Q2 emitter
24 V - 15.5 V = 8.5 V
Q1 is Uin subtract Q1 emitter.
24 V - 16.1 V = 7.9 V
Q3 is Collecter subtract the emitter
16.7 V - 5.6 V = 11.1 V
33,325
Very good!!!
I think you've got it down.
If the base current has a value of relevance then you need to take it into account. What constitutes a value of relevance depends on the circuit and the specs, but a general rule of thumb is that if the base current is less than 1% of the currents "adjacent" to it then it can be ignored while if it is more than 10% of those currents then it can't. Between those limits is a judgment call, so if it doubt, don't ignore it.
Once you have worked the infinite-beta case and then gone back and figured out the base currents assuming that they don't affect overall circuit operation (which is the point you are at now), you can usually get a pretty accurate accounting of the actual effects through just one more round of iteration. For instance, let's say that the base current in Q3 turned out to be 300 uA, which would be more than 10% of the 2.82 mA flowing through R4+R3, you would look at the circuit and conclude that the voltage at the junction would still be clamped at 6.2 V and so you would still have 2.82 mA in R3, but you would have 3.12 mA in R4 giving you a Uout of 16.50 V, or one volt higher. You would then follow the analysis around just like you did before and get an updated value for the Q3 base current. If the change in that base current is small relative to the currents in the adjacent resistors, then you are probably safe calling it done. If they aren't, then you go another round and keep doing that until they are. You seldom have to make a second round and if you designed the circuit well to begin with you seldom even have to make the first update round and can stop at the point you got to.
pwnstars
Joined Feb 29, 2016
44
Very good!!!
Thanks a lot. It's very well explained :)
I'll attach another curcuit, and do the calculations when i find time.
For now, I have other homework to do, with deadline tomorrow.
Here it is.
Input 24Vac, 50 Hz
Output 12VDC, 48W
Ripple voltage is Max. 5% of Input
The components are of my own choise.
MrAl
Joined Jun 17, 2014
13,864
Here it is.
Input 24Vac, 50 Hz
Output 12VDC, 48W
When you get a chance you might also want to get a little more insight into these circuits. Step back and ask yourself why the original circuit had two more transistors added to it plus some other parts. Why would anyone want to do that. What are the advantages, if any.
pwnstars
Joined Feb 29, 2016
44
In order to make this simple. Let me use the same components as before.
Q1 gain is 50
Q2 gain is 20
Q3 gain is 110
Zener diode 5.6 V
I'll start by finding current in the output.
48W / 12 V = 4 A
Q3 base voltage is calculated by adding the zener diode voltage requirement to the diode in transistor
5.6 V + 0.6 V = 6.2 V
Now i pick a relative big resistor at R4 to make sure the current in Q3 base is rather small.
6.2 V / 500 µA = 12400 Ω
Adjusted to a real resistor
~ 6.2V / 12 kΩ = 516 µA
Now i can calculate R3 voltage
12 V - 6.2 V = 5.8 V
and resistor
5,8 V /516 µA = 11240
~ 12k Ω
Is this correct?
33,325
Q1 gain is 50
Q2 gain is 20
Q3 gain is 110
Zener diode 5.6 V
48W / 12 V = 4 A
You're okay up to this point, but then you go off the rails.
R4 does not establish the Q3 base current. That is determined by the current in R2 (less the current needed to feed the base of Q2) and the current gain of Q3. By setting the current in R4 to such a small value, you ensure that the base current in Q3 will be a significant fraction of the current through R3 and R4 and, hence, that they will have significantly different currents in them (because a significant fraction of the current in R3 is diverted to the base of Q3 and never goes through R4).
pwnstars
Joined Feb 29, 2016
44
Makes tatally sense.
To move on from here, would it be better to assume the Q1 emitter is 4 A taken from the output and use the Q1 and Q2 gains to calculate Q1 base?
4A / 20 / 50 = 0,004 mA
and after that using calcs from the Input to find R2?
33,325
Yes. The actual Q1 emitter current will be higher due to the need to feed R3, but you can (at least initially) assume that this current will be negligible compared to the 4 A.
pwnstars
Joined Feb 29, 2016
44
Got it.
Now I move to the Input.
To find the capacitor size i need to use this equation.
Ur = 8m x ( I / CL )
I know that Ur ( voltage ripple) cannot go beyond 5% of the input of 24 VAC
Ur = 5% * 24 V = 1.2 V
Now i can put that into the equation, but i still need a precise current value? The only one i have at this point is the 4 A - so lets go with them.
1.2 V = 8m x (4A / CL)
now I isolate CL
CL = (8m x 4A) / 1.2 V = 26.7 mF
Does this sound reasonable?
33,325
Before I can start to answer that, I need to know where this ripple voltage is being measured? Normally you only care about the ripple in the output, but that would mean that you have to determine the power supply rejection ratio of the regulator, which I don't think you are in a position to do. So where is the ripple being measured?
33,325
Trying to calculate the voltage generated over the capacitor and finding the ripple at C1 is part of the task.
Okay, so the ripple at C1, not the ripple at the output.
Are you sure that the spec is as a percentage of the input? Since the input is RMS, you need to find the RMS ripple voltage.
