MisterBill2
- Joined Jan 23, 2018
- 28,112
OK, and interesting. Now, as an alternative that will allow much greater flexibility and quite a lot better reliability, I suggest using a small PLC, (Programmable Logic Controller). First reason is that as a complete package there is no need to experiment with trying to get it to do what you want. Second reason is that the hardware issues are already solved for you, including the package, power, and connections. And from the right supplier, the programming software is a part of the package, so no guessing how to make a timer or a counter work. That will allow experimenting with waveforms and amplitudes to be the focus.
I recommend Automation Direct as the supplier because they are not only honest, but also they are good with customer assistance. And the smaller simpler PLCs probably cost the same as the bunch of experimental hardware that will still need to be packaged and powered.
