How to connect my K0 input???
What is G0? If it is always 1 and you need something that is always 0, what do you think the answer is?GND, but my G0 is always 1 can i use that,
and how i would connect K0 in other situation when is 0
You're skipping a step here. You need to generate the full table and use Kmaps to get the correct expressions.GND, but my G0 is always 1 can i use that,
What chip is this?![]()
It would appear to be four J-K flip flops.What chip is this?
Connected how?It would appear to be four J-K flip flops.
Did you generate the equations to implement the counter?Thanks, I understand.
Based on your tables, J1 isn't always equal to 1. You have several don't cares for J1, so what J1 actually is for those cases is dictated by the specific (and so far unspecified) way you implement the logic to get the values for J1 that you DO care about. If you are going to rely on J1 always being 1 so that you can generate K0 from it, then you no longer have any don't-care entries for J1 because you very much DO care about every single one of them. Update your tables accordingly. If you don't, then you run the very real risk of grouping terms to minimize your logic and leaving out one of those x's that really should have been a 1.Because my J1 is equal 1, a take that 1 and inverted, and connect to K0.
Why wouldn't you just connect K0 to GND? Or since Q0 is always 1, connect it to Q0'?Because my J1 is equal 1, a take that 1 and inverted, and connect to K0.
That's why I asked how this was being implemented way back Post #4. The original question sounds like the TS doesn't know HOW to connect K0 to GND. But without know how this is being implemented, it is impossible to tell him how to do it. Every simulator or synthesis tool has SOME way to tie a logic signal hard HI or hard LO, but HOW that is done varies from tool to tool.Why wouldn't you just connect K0 to GND? Or since Q0 is always 1, connect it to Q0'?
This thread *is* progressing at an unusually glacial pace... And the OP has selecting reading (or answering)...That's why I asked how this was being implemented way back Post #4.
Not unusual, unfortunately. But the OP does seem to be making the effort (in this and elsewhere). I think there is a pretty strong language barrier that he is dealing with.This thread *is* progressing at an unusually glacial pace... And the OP has selecting reading (or answering)...
