Thanks for replying. I'm really weak on analog thinggy, Could you please give more detail on it.Originally posted by n9352527@Nov 21 2005, 06:27 AM
This type of signal is common in some communication/modulation systems. If the frequency is pretty low and the signal is strong then a few signal diodes would do the job. But if you need to operate at high frequency or worry about loading the signal source then you need to use opamps to separate the pulses.
[post=11798]Quoted post[/post]
A simple two diodes circuit is attached.Originally posted by thong@Nov 21 2005, 04:40 PM
Thanks again
[post=11812]Quoted post[/post]
OpAmps are terrible for comms I thought. I remember seeing their low roll of freq due to their internal cap. Typicall 20-40Khz.Originally posted by n9352527@Nov 21 2005, 06:27 AM
