Sensor - the difference between gasoline and diesel
Motanache
Joined Mar 2, 2015
652
It is useful to design a sensor to differentiate between gasoline and diesel.
Both do not conduct electricity.
But they are very different!
Diesel is a lubricant.
Gasoline is a solvent.
Deleted member 115935
Joined Dec 31, 1969
0
sounds like a home work question ?
drc_567
Joined Dec 29, 2008
1,156
A sensitive smoke alarm detector may be capable of sensing the volatile components of gasoline, which can evaporate at room temperature. Diesel is less volatile, having a boiling point greater than water.
AlbertHall
Joined Jun 4, 2014
12,653
There are flammable gas alarms available so they should detect petrol.
38,860
It's certainly possible to sense the difference between the two.
It's the application and cost of the sensor that determines how you would do it.
drc_567
Joined Dec 29, 2008
1,156
... A good suggestion.
The smoke alarm in the kitchen here seems to be hyper-sensitive, going off when there is any trace of smoke, steam, or even hot air from the open oven door.
18,173
Freezing point is yet another potential method.
The choice of method depends on the context, the budget and so on. All the things we haven't heard yet.
Motanache
Joined Mar 2, 2015
652
Refractive index. But it differs little, only at the third significant digit. That's hard to do in diy.
It's not exactly what the figure should be. I haven't found a better one.
How to measure the refractive index with sufficient precision, not accuracy?
The refractive index is n = c / v
If we measure a fixed distance with this laser module ....
It will give different results depending on the refractive index of the environment through which the light passes.
The accuracy of this module is 5% Too imprecise to detect the small difference.
Motanache
Joined Mar 2, 2015
652
Let's measure the dielectric constant, again they are very close.
However, the viscosity differs a lot.
18,173
From those tables, viscosity has good discernment but is not trivial to measure.
I think it could be trivial but we don't know the constraints. Flowrate thru a small orifice at controlled temperature would do it. Or pressure drop across an orifice at a defined flowrate.
Density isn't hard to measure either, depending on what techniques are allowed.
sparky 1
Joined Nov 3, 2018
1,218
A material composition that reacts with one vapor and not the other would allows that distinction.
If increased sensitivity is needed the size of the receptor area and the number of receptors increases sensitivity.
Dogs can be trained to sniff out a variety of liquid vapors. It is the number of receptors or larger sensors that do that.
The metod of samplng could change but sensing 3 out of 5 properties could show a diffence in data.
