Difference between thermal imaging sensor and Raspberry Pi NoIR Camera
scoobydoo
Joined Nov 25, 2013
9
OBW0549
Joined Mar 2, 2015
3,565
Infrared cameras like the NoIR respond to what is called near-infrared, just beyond the visible spectrum past the red end. They do not respond at all to the much longer (like 10X longer) wavelengths associated with thermal imaging. Using imaging math with the NoIR camera isn't going to change that.
kubeek
Joined Sep 20, 2005
5,796
What the NoIR is is just a normal camera sans the IR blocking filter, so it can see things like IR remotes and stuff. As Obiwan0549 ;) said, the wavelength of thermal radiation in the normal range of temperature is too far away from what that camera can sense.
kubeek
Joined Sep 20, 2005
5,796
And now that I think of it, even if the camera were sensitive in the heat infra red, it would not be able to distinguish between hotter and colder pixels, and definitely not do anything that could correlate to their temperature. The RGB cells are simply not capable of doing that.
