Sensor Bypass
HighVoltage!
Joined Apr 28, 2014
182
I want to temporarily bypass a normally open low pressure sensor upon starting a pump. Because there is no pressure, the sensors logic is 0 or OPEN. When When there is pressure above 5psi, the switch will CLOSE.
The sensor is in series with the 120VAC circuit, in which will de-energize coil if pressure drops.
Goal: I can probably have a momentary push button in which I can hold to short-out sensor upon starting (DONT LIKE)
Can I use a time delay relay to energize an auxiliary relay/contact to short out sensor.
Any other ideas on how to temporarily short-out sensor upon start? Otherwise, pump will not start.
danadak
Joined Mar 10, 2018
4,057
A standard well pump under / over pressure switch has a lever attached
to bellows. When pressure is under user rotates a lever that manually
closes contacts to pump starting it. As pressure rises bellows inflates and
slowly takes off required torque on lever until user no longer has to hold it.
Then pump runs from a low pressure setpoint to high, shuts off, and cycle
is repeated w/o user intervention when pressure drops , but not all the
way to kill pump due to total loss of pressure.
Regards, Dana.
HighVoltage!
Joined Apr 28, 2014
182
Regards, Dana.
This would be ideal. However, there is already an existing lp cut-off switch in which I intend to use somehow ;)
HighVoltage!
Joined Apr 28, 2014
182
This relay circuit should do it but you need a wall wart power supply or battery to operate the relay.
This is great. However, I do not want the pressure switch to remain shorted. Upon reaching a pressure greater than 3psi, I want the switch to NOT be shorted. Under a low prrssure condition, the switch will disengage a latch circuit, resulting in the pump shutting down.
38,498
He didn't want to switch 480 volts.
Of course not.
The pressure switch controls 120v which controls a relay that switches the 480V to the motor.
Read all the posts.
He just doesn't want to have to hold the start button until the pressure builds up above the its pressure setting.
