We have verified that we are using +12V to turn on the MOSFET. We have turned it up to +14V to make sure, with the same result. The threshold voltage for the MOSFET we are using right now is only ~5V.If you are leaving it on, are you certain that the gate voltage is enough to guarantee full conduction? 120 milliohms and 14 amps is only 1.68 watts. Make sure the gate is at 12 volts, but not over 20. Any resistance in the source circuit will raise the source voltage and may cause partial turn off, as the gate has to be at least 10 volts above the source.
I have some pictures of the entire project posted here, so you can get an idea of what the thing looks like. I know it looks like hell right now, but we'll fix it up once we get the circuit working properly.
I went down to verify that we could adjust the output voltage using the control circuit to control the field current on the alternator. This was successful. I was able to push 15A through the field circuit, without trouble. This was all the testing I did though, as we will have to do a lot of rewiring to make the circuit work this way permanently.
I just don't understand why we can push 15A through the field circuit, but cannot push 14A through the motor without trouble. In addition, during this test, I didn't have the MOSFET attached to a heatsink, or have a fan blowing on it. I only tested it for about a minute, but there were no heat issues. The two we fried yesterday were gone within 10 - 15 seconds, while inside our heatsink. We will have to get the clamp on ampmeter again (borrowed it from a professor), and check the current through the motor with the new MOSFET (though last time we checked it, we checked the current without a transistor in the circuit, to get a worst-case-scenario of ~14A continuous).
We are nervous about using the control circuit to control the field current... Will the field collapse cause us problems? When we use the control circuit to turn the motor on and off, the motor continues to spin, which allows the field to remain, taking less of a pulse to get it going again (which is why PWM works). I'm not sure using PWM on the field circuit will work in the same way.
Anyway, please let me know your thoughts about what the latest tests indicate... I am really scratching my head here.
