hi guys this is my 1st post in this forum !!
I need send data between pc and pic so i made this schematic using proteus wrote the very simple ccs c code for pic 18f2550
and my schematic is goto http://obrazki.elektroda.pl/2276196000_1388233204.jpg
and when i run the code the result is like this http://obrazki.elektroda.pl/6774018100_1388233383.jpg
so friend before this i used exsisr.c with little change
so proteus result for this is http://obrazki.elektroda.pl/5680434400_1388234039.jpg
SO in the both above cases i clicked on rx vir: terminal pressed keyboard buttons but they(the characters i pressed) did not appear in output terminal
if i say clearly in first case (according to my little code) i pressed keys buttons but output is like in image ("start typing" then nothing..)
in second case the long code i keep pressing keys for 10s but output like the image i added ( bufferd data..bufferd data.. as in there)
And also i Used hyperterminal with virtual serial port software in second experiment but same results came as in image..
I'm using proteus 7.8
Think u clearly got my problem and show me how to fix this...
please help me guyssss!!
thankzz
Rich (BB code):
#include<18f2550.h>
#fuses NOWDT,HS,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,INVERT,parity=N,bits=8)
void main()
{ char a;
printf("Start typing ...\n.");
while(1)
a=getc();
putc(a);
Rich (BB code):
#if defined(__PCM__)
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#elif defined(__PCH__)
#include <18F2550.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS,INVERT)
#elif defined(__PCD__)
#include <30F2010.h>
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, UART1A)
#endif
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr()
{ int t;
buffer[next_in]=getc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc()
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
next_out=(next_out+1) % BUFFER_SIZE;
return(c);
void main()
{ enable_interrupts(int_rda);
#if defined(__PCD__)
enable_interrupts(intr_global);
#else
enable_interrupts(global);
#endif
printf("\r\n\Running...\r\n");
// The program will delay for 10 seconds and then display // any data that came in during the 10 second delay
do
{ delay_ms(10000);
printf("\r\nBuffered data => ");
while(bkbhit)
putc( bgetc() );
} while (TRUE);
thankzz
