Hello All,
I am using Quectel's BG96 module to send data to some cloud services using MQTT Protocol.
'Quectel_BG96_MQTT_Application_Note_V1.0' is documented well and I am following the same.
According to its section 3.2.8, we need to send CTRL+Z, to send user data to cloud, once ">" is responded from the module.
While using QNavigator (Quectel's AT Command tester) I follow the same procedure and I can publish my data to the cloud service.
The problem is that I don't know how to send CTRL+Z via UART, specifically in this case.
Can any one help me out here?
Suppose I want to publish "Quectel" on a cloud, how should I embed CTRL+Z with the string "Quectel" in my UART Transmission code?
Thanks & Regards,
Maunik Patel
Thanks & Regards,
Maunik Patel
