Send a byte on a pin
pjreijiri
Joined Aug 19, 2015
117
Just one note, correct me if I'm wrong, but the frequency is 8Mhz which gives me a shorter period. even after Fosc/4 it would give me 0.5us
Sensacell
Joined Jun 19, 2012
3,787
The code to receive is more complex than to send.
You can see that if your clock period is 500ns, trying to bit-bang DMX data rate leaves only time for 8 CPU instructions per bit.
Probably not workable.
Sensacell
Joined Jun 19, 2012
3,787
8 instructions per bit is not enough granularity to effect clean serial transmission.
it works if the baud rate is much much slower than the instruction clock, you can then balance the timings and make it work.
Using a timer interrupt for example, this would make the timing consistent, even while the CPU was running other tasks.
However, 8 instructions is already more than it would take to handle the basic interrupt housekeeping tasks.
What is the baud rate of your Bluetooth module?
jpanhalt
Joined Jan 18, 2008
11,087
The 16F887 is spec'd up to 20 MHz (200 ns per Tcy). A bit-banded version of transmit and do it in roughly 10 Tcy = 2 us per bit. Here is some code that was originally from Mike McLaren (K8LH). He may have shortened it since. It is for a different chip,but translating it to the 16F887 shouldn't be difficult.
Code:
;                             PUT232
; Put232 (9600 baud) -- Mike McLaren, K8LH (Jan-09)
Put232
     movlb     2
     movwf     txbyte          ; save Tx data byte
     movlw     10              ; 1 start + 8 data + 1 stop bit
     movwf     bit_ctr         ; setup bit counter
     bcf       status,0        ; C = 0 (start bit)
     DelayCy   (104*usecs-10)  ; 104 usecs minus 10 cycles(added)
     goto      SendBit         ; send start bit
NextBit
     bsf       status,0        ; always shift in a 'stop' bit
     rrf       txbyte,f        ; put data bit in Carry
SendBit
     movf      LATD,W          ; read port
     iorlw     1<<1            ; set Ser_out pin bit to 1
     btfss     status,0        ; if data bit = 1 skip, else
     xorlw     1<<1              ; set Ser_out pin bit to 0
     movwf     LATD            ; precise update intervals
     decfsz    bit_ctr,f       ; done? yes, skip, else
     goto      NextBit         ; send next bit
     retlw     0               ;
John
