Selecting Power supply
bertus
Joined Apr 5, 2008
23,029
That will do fine.
If you are going to use the powersupply for both boards, increase the buffer capacitors to 2200uF.
Greetings,
lubnaan90
Joined Jan 13, 2010
198
That will do fine.
Greetings,
Thank you ,
Yes ! as per your advise , i am definitely going to use the Transformer for powering both the boards, as it is powerful enough .
Noted about using 2200uf Capacitor .
bertus
Joined Apr 5, 2008
23,029
When you look in the datasheets of the LM78XX and 79XX you will see there are always two small capacitors around the stabelizer.
One at the input and one at the output.
The capacitors are there to prevent the stabelizer from oscillating.
In the schematic I gave you (from a dutch site) there are only the capacitors at the output (1 uF at the 78XX and 2.2 uf at the 79XX).
Greetings,
lubnaan90
Joined Jan 13, 2010
198
Greetings,
Understood , thank you for your reply.
lubnaan90
Joined Jan 13, 2010
198
You could try something like this using transformer 6:
Greetings,
Hello ,
I finished building the PSU board , i have attached the picture .
will be testing the Project today & will give updates .
Plz do let me know if you have any comments .
Audioguru
Joined Dec 20, 2007
11,248
I have the writeup for the project. Its power supply voltages are not mentioned.
The linear LM3914 voltmeter IC should be a logarithmic LM3915 VU meter IC.
The LM391x has LED currents set to 12mA. If the MODE switch is set to BAR, the supply is 12V, the LEDs are 2V red ones and are all turned on then the LM391x will dissipate 1.2W and will be extremely hot.
The project has the problem that the LEDs are multiplexed so their 12mA peak current will look dim with an average current of only 1.2mA.
bertus
Joined Apr 5, 2008
23,029
Did you use a second bridge rectifier for the second board?
You can connect the second stabelizer direct afther the brige of the first board (on the positive capacitor).
When connecting the grounds together now there will be problems.
Greetings,
lubnaan90
Joined Jan 13, 2010
198
Greetings,
Hello ,
I have simply Connected the small PSU Board to the AC line from the transformer.
The small board is using a rectifier Chip RS 205.
lubnaan90
Joined Jan 13, 2010
198
Really Frustrated & Sad ,
for some reason , the transformer just gave up , It seems it has internally burnt , its Like a Hotrod now :-((( .
I did check the PSU boards before i connected them to the Analog & the digital boards , they were working fine , this happened only after i connected Analog & the Digital Boards to the PSU.
"Details of the Test"
Connected every thing for test run,
Seems op amp was not working ,
The digital circuit seems to be working fine , once i switched the power supply ON & connected the audio signal to the board, the lights in the matrix started Dancing . for a moment i thought the Project is a success ,not until i disconnected the audio signal , even with out the audio signal the Lights were dancing , it seems its the LM3914 IC which was doing that
. Wanted to check further whats the Problem & the Transformer Gives up .
bertus
Joined Apr 5, 2008
23,029
As I told you you would expect trouble the way the powersupplies where connected together.
Can you make a schematic how you actualy did connect the powersupply-boards?
Greetings,
lubnaan90
Joined Jan 13, 2010
198
Greetings,
Yes i understand , it seems I committed a very small error which cost me a Very good transformer .But its ok , i guess it was an error to learn from.
I have attached the Schematic .
bertus
Joined Apr 5, 2008
23,029
As you can see now the second brigde rectifier did short the transformer when you connected the - to the ground.
Here is what I had in mind with the second stabelizer:
Greetings,
lubnaan90
Joined Jan 13, 2010
198
Greetings,
Thank you for the Schematic ,will consider it aswell.
I'll probably buy a new transformer Tomorrow & test the Project.
lubnaan90
Joined Jan 13, 2010
198
Greetings,
Hello ,
Bought a New transformer (the one which you recommended).
I really wish to avoid blowing this one up .
I have attached a picture of the transformer, I am a little confused regarding the output of the transformer ,
Which one is Ground (common) & which ones are the positives ?
As i see here its SEC1 = pin 6&7 , SEC2= 9&10 .
bertus
Joined Apr 5, 2008
23,029
With the shown transformer you can make the center tap by connecting 7 and 9.
The bridge can be connected to 6 and 10.
(the dots show the same phase).
Greetings,
