Hi everyone,
I'm new to this forum. I think that somebody here must know what I need to do for my project.
I have built a cat wall for my 2 maine coon cats. It has 6 different habitats in it. I never know which habit my cats are in. I've attached a pic of one of the habitats; they are all similar. It is carpeted so my furry friends are comfy and they often sleep in them.
I'm close to completing the project. This is in my theatre / entertainment area.
What I hope to do, with the most conservative spend that I can get away with is have a visible light(s) mounted that could do any one of the three things listed below, in order of preference:
A) a single LED light that will shine red if the habitat is occupied and green if it is not.
B) Two LED lights, one red, one green. The red would be on if occupied and the green if it is not.
C) One LED light that simply turns on when the habitat is occupied
These habitats have about 1' square of carpeting on the bottom held on with adhesive that i could slip some sort of small pressure or weight sensor underneath.
It is built on a false wall and the adjoining room is a utility room that is simply framed in, so I can easily run any necessary wires behind the wall and drill a small hole through.
I did do an LED light project that for a newbie like me was really easy and I was hoping this wouldn't be alot more complicated than that. I bought a controller and a string of lights and the controller gave Alexa the ability to turn the led strip on or not. I no longer think it's quite as simple and there probably isn't a packaged solution available for it, but I just can't see it being incredibly complex or expensive.
Do you have any advice or could you point me in the right direction so I can try to figure out a solution please?
Thank-you all for your assistance !
James
James
