Second Order Circuit
Bernardri
Joined Dec 17, 2018
5
Hello, I would like some help with this second order circuit exercise.
I did'nt understand why the solution says that V (0) = -30 V.
Also, I did not understand why the capacitor's voltage (Vc) is -30 V.
Isn't the voltage for t <0 (when the capacitor is loaded) the same as the voltage source?
The exercise asked for the circuit below i(t) for t>0 . The switch opens at t=0 after a long time closed
My attempt:
For t<0: V(0)= 30 V and i(0)= 15 A
For t>0:
α= R/(2L)= 2/(2*0,5)= 2
omega = 1/sqrt (LC) = 1/sqrt(0.5*0.25) = 2.82942712475
Under-damped:
di/dt= -2(15 cos(2t)+ B sin(2t))e^-2t + (-2*15 sin (2t) + 2 Bcos(2t))e^2t
di(0)/dt = -30+ 2B = -(1/L) [R*i(o)+ Vc(0)] = -2 [30+30] = -120
-30+2B=-120
B= -45
i(t)= 15 cos (2t) + (-45 sin (2t))e^-2t A
So, the answer isn't the same as the book's solution.
MrAl
Joined Jun 17, 2014
13,864
My attempt:
For t>0:
Under-damped:
-30+2B=-120
B= -45
Are there some things missing from this problem statement?
I ask because the bottom of the second circuit diagram looks like it is missing.
Also, is the -30v the initial cap voltage? That's what it looks like, but it would be better if we could see the whole problem statement and also the solution too. This is not a difficult problem but we need the exact problem specification to answer adequately.
