hi ganny,
Look at the 74LS192 for up/down BCD and 74LS247 for 7 Segment drivers.
As your query is a homework assignment, we would expect you to post your effort in creating the circuit.
Eric
Sorry, it should increment 1,2,3 from 000-100 for example from 000 I push the button for increment of 2 the output will 002 when I push the button for increment 3 the output will be 005. Thats what my problem is
OK,
I would recommend that you initially limit the circuit to one CD4026 IC, until you get that one counting from 0 to 9.
If you are using a mechanical switch for the Clock source, it requires 'debouncing', that means as the switch is closed the contacts may bounce and cause multiple clock pulses.
Do you have a Schmitt logic gate available to make a debounce circuit?
A CD40106 , CD4093, ?
E
