science behind a speaker coil
SamR
Joined Mar 19, 2019
5,542
How much do you know of electric and magnetic field effects? That would be a good start on the basics...
Reloadron
Joined Jan 15, 2015
7,962
Simply put, real simply put, How do speakers work? That is a very basic overview. What you have not mentioned is how much power do you expect this speaker to handle? That will be a part of determining the coil wire gauge you wind your voice coil with. You also make no mention of core size? Material? Frequency response and the list continues. I suggest simply researching speakers in some detail to where you gain enough understanding as to why speakers work and how they work.
Ron
sebashtun dakeng
Joined Oct 19, 2018
9
Ron
thank you :)
Audioguru again
Joined Oct 21, 2019
6,826
The magnetic gap in a speaker's magnet structure will be very difficult to make narrow but still allow the voice coil to move in and out of it without rubbing.
The spider that keeps the parts from rubbing will also be difficult to make.
The brushless motors in my electric radio controlled model airplanes play a little tune when they are initialized, and they scream loudly for a moment when overloaded before being cutoff.
