Sawtooth wave Mathematical Form
WBahn
Joined Mar 31, 2012
33,324
So... you just want someone here to do your homework without you even making any attempt at all?
And you want them to use their crystal ball to determine the time and amplitude parameters?
Picbuster
Joined Dec 2, 2013
1,062
What happened?: the voltage V goes over a period of time(t) from +V to -V and then (theoretical) in zero t to +V.
It's linear each moment in (t) will produce a Voltage V.
One period consist out of V high negative High.
Now you are able to express it form into V and (t).
So open your handbook mathematic section about linear equations and their visualisation.
Picbuster
MrAl
Joined Jun 17, 2014
13,864
Hi guys! please see attachment...there will be sawtooth wave ..kindly represent this wave into its mathematical form...thank u so much
As others have said, we do not know what form you need the solution to be in. There are many different forms for the solution such as:
1. Computer code form y=f(k).
2. Time domain form f(t).
3. Frequency domain form F(s).
4. Fourier series form Sum(...).
5. Sequence form {y1, y2, y3, ...yn}
6. Nested series f(f(f(...))).
7. z domain form F(z).
Pick one and show some work so we know what you need, otherwise we cant know what you really need.
